This post has been edited by jjb16033: 30 December 2007 - 06:54 PM
Page 1 of 1
CUSTOM ALUMINUM FLATBED FOR SALE Aluminum flatbed with toolboxes and gooseneck hitch
Posted 09 October 2007 - 02:17 PM
HELLO, I AM SELLING MY CUSTOM ALUMINUM BED OFF MY FORD F-350 TRUCK. THE TRUCK IS NOT FOR SALE JUST THE BED. THIS BED IS BUILT HEAVY-DUTY AND THE BED IS 9'6" LONG X 8'3" WIDE WITH A GOOSENECK HITCH OPENING, AND ALUMINUM OPENING COVER. THE REESE GOOSENECK 2 5/16" BALL MOUNT HITCH, RAILS, AND ALL MOUNTING HARDWARE GOES WITH IT ALSO. THE GOOSENECK BALL MOUNT HITCH IS RATED FOR 25,000LBS GTW. AND 6250LBS VERTICAL WEIGHT. THE OUTER FRAME OF THE BED IS 5" THICK AND FROM FRONT TO BACK THERE ARE 3" ALUMINUM CHANNEL EVERY 12" AND THEY ARE WELDED TO THE MAIN 5" THICK CHANNEL THAT SITS ON WOODED BLOCKS AND FASTENED DOWN WITH TWO HUGE U-BOLTS AND I THINK 4-6 OTHER BOLTS. ALL THE WOODEN BLOCKS AND BOLTS GO WITH THE BED ALSO. THE BED HAS 6" WIDE X 1 3/4" THICK TREATED WOOD ON THE FLOOR AROUND THE OPENING FOR THE GOOSENECK HITCH AND IS SCREWED DOWN TO THE CHANNEL. THE FRONT OF THE BED HAS A 2" X 3" ALUMINUM TUBE CAB PROTECTOR. THERE ARE (4) DIAMOND PLATE ALUMINUM TOOL BOXES MOUNTED UNDER EACH CORNER OF THE BED. THE TWO IN THE FRONT ARE 30 1/2" LONG X 18" DEEP X 18" TALL. THE TWO IN THE BACK ARE 24 1/2" LONG X 18" DEEP X 18" TALL. ALL THE TOOL BOXES HAVE A 1" THICK SOFT RUBBER LINED IN THE BOTTOM. THERE ARE DIAMOND PLATE ALUMINUM WHEELWELLS MOUNTED TO THE BED WITH MUD FLATS. THE ALUMINUM PLATE ON THE BACK HAS BACK-UP LIGHTS MOUNTED TO IT AND IT GOES WITH THE BED. EVERYTHING IS STILL IN GREAT SHAPE JUST NEEDS A LITTLE POLISHING. THE BED AND EVERYTHING I MENTIONED WAS MADE AND INSTALLED IN 2004 FOR JUST UNDER $10,000. I AM ASKING $2500. FOR EVERYTHING. I CAN EMAIL YOU PICTURES FOR SOME REASON I CAN NOT GET THEM TO UPLOAD ON THIS SITE THANKS.
Posted 24 May 2008 - 07:54 AM
Do you still have this bed for sale. If you do where are you located. my email is maverickconst@aol.com
Posted 19 November 2008 - 07:47 PM
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
