Will Bronco front brake lines and rear brake lines fit a 1970 4X4 with a Dana 44. Having trouble finding brake lines to fit this truck.
1970 F-100 4X4 brake lines
coryb
, Dec 13 2007 07:47 AM
Posted 14 December 2007 - 05:00 PM
Yes and No. The F-100 has a wider stance so the brake lines are a little longer. The brake hoses are also alittle longer. Both the lines and hoses are the same size at the connections and would swap if the length is not a proplem. I completly re did my brake lines and hoses last winter on my 70 f-100. I put in a 4 inch lift so I bought early bronco extended brake hoses from JBG. and universal brake lines from auto zone. Hope that helps RKDxpress.
