I have a 1968 F-100 that has a 390 in it. It blows oil out faster than I can put it in. I can buy a rebuilt 460 and transmission pretty cheap from a friend. How tough is the switch over? Will the motor mounts work?
390 to 460 in 1968 F-100
swatdog51
, Mar 11 2008 04:39 AM
Posted 01 October 2009 - 06:25 PM
you will need different engine perches. a different exhaust system and a different driveshaft probably. becuase of length and slip in vs bolt on yokes on the two transmissions.
Edited by fordtruckman, 24 March 2010 - 09:37 PM.
Posted 14 March 2010 - 12:12 AM
i have a 1970 f-250 ford rruck my mechanic says that were getting no spark.i have a msd ignition systen. he gets spark when we bewnch test the distributer,but when we drop it in the truck it seems like it grounds out. he scraped off some silicone from the distributer.could that be my problem?
Posted 16 April 2011 - 04:59 PM
73 to 79 460 mounts will get that 460 in your 68,I used them to put the 460 in my 66 and you might have to move the trans crossmember back a little and drill new holes in the frame.
