i have a 78 f-150 ranger and this is my first actual truck that i have owned and until i bought an 82 this was my only ride. i had to replace the bearings on the driver side three times and now i have to replace them again along with the spindle what could be causing this?
bearings
Van Kleeck
, May 24 2008 03:01 PM
Posted 05 June 2008 - 05:45 PM
Which bearings? Inner or outer, 2wd? If it is 2wd maybee the race on the drum/rotor is bad, I would have that changed anyway. Maybee the spindle itself was screwed up, hopefully it was and now that your gonna change it you won't have anymore problems. Hope that helps, Jack
