I would like to swap out my idiot light cluster for a full gauge cluster but not for sure on the amp gauge?? I was told that I need to run a wire that goes to the alternator but splice it between the shunt and the factory harness up by the solenoid or something like that.... Has anyone done this and if so please help.
How to wire a full gauge cluster?
alconk
, May 30 2008 01:14 AM
Posted 10 September 2008 - 04:00 PM
well,not too bad,first off there is a different wiring plug,i did this awhile back,what i did is i made my own diagram,i marked the colored wires on a piece of paper on both plugs,so do you have the other plug,if you do just pull back the wires with a pointed object to insert in the plug then pull back the wire.the only trouble i had was the green wire which is voltage regular i plugged it in the wrong slot,anyway it's ok now,so good luckI would like to swap out my idiot light cluster for a full gauge cluster but not for sure on the amp gauge?? I was told that I need to run a wire that goes to the alternator but splice it between the shunt and the factory harness up by the solenoid or something like that.... Has anyone done this and if so please help.
