F-150 won't stay running
#1 sonny
sonny
Posted 24 July 2008 - 03:10 PM
My F-150 stops running while I am driving along like I ran out of gas. I replaced the fuel filter/then the fuel pump/then the fuel relay switch and still have the same problem. Sometimes it will stop like you are out of gas and if I let it coast it will go again. Has anyone had this proglem?
Edited by sonny, 24 July 2008 - 03:12 PM.
#2 andre 244
andre 244
    Duck Tape L'fixer :)
  • PipPip
  • 23 posts
Posted 10 August 2008 - 05:02 AM
ok do u have one or two fuel pump
some model have in tank fuel pump
some under driver frame rail
some have the two of them
did u check fuel pump cut off switch ??
also check wire on lf fender that feed pump under booster
run the truck and shake wire c if cutting out
hope this help
