Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech: Cab swap - Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech
Page 1 of 1
Cab swap
#1 User is offline   197fine
  • F-Series Newbie
  • Group: Members
Posted 24 July 2008 - 07:53 PM
Will the cab from a 1975 f350 1 ton dually fit on the frame of a 1979 f150 4x4? Both are standard cabs. If so is it a direct bolt on? thank you ;)
0
#2 User is offline   freeto4wheel
  • Duck Tape L'fixer :)
  • PipPip
  • View blog
  • View gallery
  • Group: Members
Posted 07 February 2009 - 09:42 PM
the rear mounts are different f150 and f250 use the center cross memeber under the cab to bolt down f350 cab has its own cab mounts on the outside of the frame you can make new hole in the cab floor to line them up not a big deal the wiring will be a little different in the cab but you can move the harness over doesnt take long if you pay attention while you work i switched mine out in a day and started putting the dog house back on the next day
0
Page 1 of 1
Fast Reply
