leaf spring bolts
50jersey
, Sep 05 2008 04:56 AM
4 replies to this topic
Posted 23 September 2008 - 01:17 AM
Need just a little more info. Are you talking about the centerpins in the spring packs or the mounting bolts for the shackels and spring eye? The centerpins you can get from most parts house's they come in diffrent sizes and most are cut to length. As for the shackels and spring eye Ford used a Grade 8 Bolt with a shoulder head and nut. Hope this helps.hi,can anybody help,ford has special bolts for leaf springs do anyone know what purpose are those special bolts.
Go Big or Go Home
Posted 21 February 2009 - 07:54 PM
Grade 8 might work good - but I prefer hardened and tempered. Grade 8 is only hardened. Axle - U bolts hold the axle to the springs. Leaf spring centering studs hold all the springs in a row (along with the midway clamps near each end). And eye bolts hold the leaf spring ends the the shackle or brackets. Unless you mean the rivets holding on the actual brackets to the frame.
Posted 29 April 2009 - 02:55 PM
yes, sorry about that.grade 8 with shoulder head bolts,what.s the purpose of the shoulder head,thanks kenNeed just a little more info. Are you talking about the centerpins in the spring packs or the mounting bolts for the shackels and spring eye? The centerpins you can get from most parts house's they come in diffrent sizes and most are cut to length. As for the shackels and spring eye Ford used a Grade 8 Bolt with a shoulder head and nut. Hope this helps.
Posted 29 April 2009 - 03:14 PM
the shoulder acts like a flat washer, and eliminates one by having it molded to the bolt head. you'll see the same on the nuts.
