I have a 79 ford f250 with a 300 straight six with an np435 and I'm swapping in a 86 ford 302 that was matched with a c4 or c6 ? . i was wondering wither or not i will need to find a bell housing, clutch, radiator, motor mounts etc for a 86 302 or a 79 302. any and all help would be appreciated.
![Photo](http://www.gravatar.com/avatar/271df4b5caf5052ba3e977e2e42be4ec?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
300 to 302 engine swap
booger
, Sep 15 2008 04:40 PM
4 replies to this topic
#2
Posted 23 September 2008 - 12:44 AM
I'm not sure on the radiator but the bellhousing is the same as the 300 six. You will need to get a Flywheel for the 86 model 302 as well to prevent any engine balance issues. Everything else from '79 should work.I have a 79 ford f250 with a 300 straight six with an np435 and I'm swapping in a 86 ford 302 that was matched with a c4 or c6 ? . i was wondering wither or not i will need to find a bell housing, clutch, radiator, motor mounts etc for a 86 302 or a 79 302. any and all help would be appreciated.
Go Big or Go Home
'79 Supercab 460 3" body, 6" suspention lift 38.5" Boggers Ox lockers Frt and Rr
#4
Posted 25 September 2008 - 05:56 PM
I'm not positive but chances are that you will. The only reason I can think you would is for the distributor. It could be wired a little diffrent. One quick way to see is check to see if '86 and '79 use the same part number. You could look for a distributor from a '79 and compare the plug too, or just swap it in. Hope this helps.
Go Big or Go Home
![](http://www.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
