Vibration On Decel
Guest_207racing_*
Posted 11 March 2004 - 11:46 AM
Posted 11 March 2004 - 11:52 AM
Guest_207racing_*
Posted 12 March 2004 - 10:40 AM
Wouldn't that vibrate all the time if it were a rim or tire?You could also have a tire out-of-balance, or a bent rim. The factory rims are really bad about getting bent and causing strange vibes. Check for any play/wear in the u-joints, too.
Posted 12 March 2004 - 11:33 AM
Posted 17 March 2004 - 08:21 PM
Just stuff I learned with my "Beast"
Police Package
351W
E4OD
31" Tires
Guest_207racing_*
Posted 23 March 2004 - 01:31 PM
Posted 23 March 2004 - 10:59 PM
Guest_207racing_*
Posted 25 March 2004 - 08:45 AM
#11
Guest_jkenny_*
Posted 29 March 2004 - 10:05 PM
BTW - should there be any play in the drive shaft where the smaller diameter rear connects to the larger diameter shaft under the rubber boot? I can move mine if I get underneath it and press up and down at this point. Memory says it moves a 1/8 inch or so. I appreciate any input. This vibration is getting better but it is starting to drive me nuts.
Thanks,
John
#12
Posted 29 March 2004 - 10:52 PM
#15
Posted 02 April 2004 - 10:34 AM
