I am thinking about buying a 98 f250 light duty (f150 body) I want to know if the f250 light duty is the same as the f150 with more leaf springs or is it differant like the diff. and transfer case etc.
98 F250 light duty vs 98 F150
schn7101
, Nov 20 2008 12:42 PM
4 replies to this topic
Posted 24 December 2011 - 07:09 PM
there are a few differances frames are diff,rear axle ,front calipers;all springs and if i remember right control arms and shocks.[ worked on the assembly line in norfolk for 14 yearsI am thinking about buying a 98 f250 light duty (f150 body) I want to know if the f250 light duty is the same as the f150 with more leaf springs or is it differant like the diff. and transfer case etc.
Posted 05 January 2012 - 04:07 PM
I have an f250 light duty 4x4 when I climb the hills on the road heading to the white mountains here in arizona. I just can't get it past 50 mph unless I use passing gear and I am running empty no load. Is that just how the engine is built or do I need to beef it up some how?
Posted 15 May 2013 - 11:47 AM
Hello all,
I have a 98 f250 ext cab 4x4 4.6l with 118136 miles on it. I am burning oil somewhere and don't know where. I don't see any smoke and no leaks.Any suggestions? Also should I add lucas to my next oil change or sea foam? What is the best one out there and will it help or make things worse/
Thanks for your help
