So my F250 either needs a new carb or rebuilt. I was wondering if the stock Motorcraft 2bbls are any good or if i should put a Holley 2bbl on it. The Holley i like is a model 2300 500 cfm with a manual choke. I dont know anyting about the Motorcraft other then its the stock 2bbl with a automatic choke. I was curious what yall thought would be the best choice.
Page 1 of 1
Carburetors Stock Motorcraft 2bbl or Holley 2bbl
Posted 13 February 2009 - 04:43 PM
motor craft two barrels are good carbs. i like my holley 500 on my 400 runs great as long as you know how to tune one and set the floats. you will have many years of good service fron holley just make sure you have a good fuel filter. there a little more picky on getting dirt in the needle valve and flooding out over a motor craft
Posted 14 February 2009 - 10:17 AM
Which one would you say is a better off-road carb? I saw that Holley makes these spring loaded off-road needle seats that will go in the 2300. Im kinda leanin toward rebuildin the Motorcraft if itll do good on angles and steep hills cause it would be cheaper...thats the way id like to go. Unless will out perform it...you think the Holley 2300 500cfm will make the truck run stonger and be worth the money?
This post has been edited by Redneck390: 14 February 2009 - 10:17 AM
1975 Ford F250 High Boy
390FE Big Block, 4-Speed, NP205
Dana 60 FF Rear
Dana 44 Closed Knuckle Front
Dana 60 FF Rear
Posted 22 February 2009 - 06:26 PM
my race car had a holley 2300 on it i hated that carb everyday used on a dirt track lots of bumping and such it constantly had to be played with. mine was moded and such so not the same but thinking if not as said set perfect it will cause problems.. i like the edlebrocks after years of messing with all kinds i stick with stock or edelbrock over a holley but that is my exp with them
Page 1 of 1
Sign In
Register
Help
Add Reply
MultiQuote
