Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech: battery goes dead - Ford F Series Zone - F150 F250 F350 Super Duty Ranger Tech
Page 1 of 1
battery goes dead
#1 User is offline   1970gto
  • F-Series Newbie
  • Group: Members
Posted 24 February 2009 - 03:27 PM
I have a 1978 F-250 camper special. New bat., alt., voltage reg., and selenoid. I put the new bat. in, drove the truck for about 20 min., shut it off and it would hardly crank. What is left that could drain the battery this quickly?
0
#2 User is offline   bronc76
  • F-Series Maniac
  • PipPipPipPipPip
  • Group: Members
Posted 24 February 2009 - 05:04 PM
double check to see if there isnt anything being left on (dome, interior lights etc.). Check to see if alt. belt tight?
76 Early Bronco Special Decor Package, 302, C4, Dana 20, Dana 44, 9", Hatteras green poly, 5.5" superlift, 36" swampers
79 F-150 Ranger 4wd 400, C6, NP 205, Dana 44, 9", Walnut glow/ Light sand, a/c cc
78 F-100 Custom 2wd 302, C4, black, a/c
97 Chevy S-10 4wd 4.3, Standard red, a/c cc
0
#3 User is offline   freeto4wheel
  • Duck Tape L'fixer :)
  • PipPip
  • View blog
  • View gallery
  • Group: Members
Posted 02 March 2009 - 08:45 AM
try to un hook your negative battery cable and put a a 12 volt test light between the negative cable and the negative battery post with ignition off doors closed if the test light comes on you have a negative amp draw go to your fuse box and pull a fuse one by one tell the light goes out you can find your draw that way
0
#4 User is offline   f25075
  • F-Series Newbie
  • View gallery
  • Group: Members
Posted 22 May 2009 - 01:59 PM
if u have a spark when u remove ur batt. cables u have a open circuit . check ur batt. with a meter with truck running u should have 12-14 volts. ive bough a voltage reg new it was bad. ;)
0
#5 User is offline   lostin90s
  • old part is good part s
  • PipPipPipPipPip
  • Group: Members
  • Interests:Wrecking yards , my kids , places with no cell phone service, and Centurion F150 crew cabs
Posted 22 May 2009 - 05:31 PM
Add a gound to it. From battery to frame and motor. I had a truck act same way every time. Not that battery got drianed but would crank slow if at all.
Parts is parts
0
Page 1 of 1
Fast Reply
