battery goes dead
4 replies to this topic
#1 1970gto
1970gto
Posted 24 February 2009 - 03:27 PM
I have a 1978 F-250 camper special. New bat., alt., voltage reg., and selenoid. I put the new bat. in, drove the truck for about 20 min., shut it off and it would hardly crank. What is left that could drain the battery this quickly?
Posted 24 February 2009 - 05:04 PM
double check to see if there isnt anything being left on (dome, interior lights etc.). Check to see if alt. belt tight?
#3 freeto4wheel
freeto4wheel
    Duck Tape L'fixer :)
  • PipPip
  • 20 posts
Posted 02 March 2009 - 08:45 AM
try to un hook your negative battery cable and put a a 12 volt test light between the negative cable and the negative battery post with ignition off doors closed if the test light comes on you have a negative amp draw go to your fuse box and pull a fuse one by one tell the light goes out you can find your draw that way
#4 f25075
f25075
  • 3 posts
Posted 22 May 2009 - 01:59 PM
if u have a spark when u remove ur batt. cables u have a open circuit . check ur batt. with a meter with truck running u should have 12-14 volts. ive bough a voltage reg new it was bad. ;)
#5 lostin90s
lostin90s
    old part is good part s
  • PipPipPipPipPip
  • 144 posts
  • Interests:Wrecking yards , my kids , places with no cell phone service, and Centurion F150 crew cabs
Posted 22 May 2009 - 05:31 PM
Add a gound to it. From battery to frame and motor. I had a truck act same way every time. Not that battery got drianed but would crank slow if at all.
Parts is parts
