I am new to all this but here goes....
I have an 84 f150 that I would like to do a solid axle swap. It has the stock IFS and I would like to put a dana 60 under it. Jeff's bronco graveyard sells a conversion with a 10" lift. If I bought this conversion kit and a dana 60, how difficult would this swap be? My goal is to run 44" boggers on the truck. It will not see a whole lot of offroading but I want it to be solid. Any help is much appreciated.
Solid Axle Swap
thetachi136
, May 22 2009 05:01 PM
Posted 23 May 2009 - 04:10 PM
I believe the mounts r built in . But if u can weld anything can be done.
Before removing the stock suspension drop a plumb bob from frame to center axle and mark on frame.
Then once u r ready to roll the 60 in for fab work u have a center line to go to . Or just get frame and all off donor (front section) You will have all mounts ,drag links and something to take measurements off of.
Just reseach and reresearch . before u start to cut .
I just touched the topic. But general idea.
Parts is parts
