Solenoid
joel77
, Jul 27 2009 09:20 AM
10 replies to this topic
Posted 27 July 2009 - 09:20 AM
Hello everyone. Love this forum, has been a great help to me. This is my first Ford truck, a 77 F-150 4x4, short bed, 351M, C6 trans, 9in. rear, Dana 44 front. My question is this: What causes the solenoid to keep dying? This is my third one in 6 months. When I try to crank over the engine, all I hear is a ratcheting sound. This is getting annoying. Any help would be greatly appreciated. Thanks.
"There is no replacement for displacement!!"
Posted 31 July 2009 - 02:06 PM
If you had problems with solenoid before, i doubt that the starter is bad since it starts after you install new solenoids. The motor can go bad in starter if you can hear the drive engaging the flywheel with a 'click'. I maybe wrong on this theory but have you asked someone if the voltage regulator has something to do with the solenoid going bad?
Posted 04 August 2009 - 08:01 AM
B I N G O """"""""""/////John
Posted 06 August 2009 - 06:37 AM
#11
Posted 10 August 2009 - 04:18 AM
ignition switch?
Thank you for all the great ideas. I got the problem fixed. I took the battery in to Advance Auto to have it tested and charged, and get an ignition switch. The clerk tested the battery and it was good and charged. He also told me that I should clean the terminals and connectors, it could be a bad connection. I cleaned them and the damn truck started right up. Can you believe it???
