Hi all, I want to know if a 1978 Extended cab and shortbed will fit on a 78 Reg cab long bed Frame. Looking into building a toy.
Truck Build
BEFord
, Sep 02 2009 05:21 PM
Posted 09 September 2009 - 12:08 PM
The only thing I can tell you is to measure the extended cab + bed versus the long bed frame, see what the difference is and go from there. I'm sure that the body mounts that are over the extended part of cab are going to have to be moved. The ones up front should be the same
