Hey guys I have a 89 f 150 4x4 I want to lift 6 inches, I found a pretty nice kit from bds suspension, my main question is, What are the little things im going to have to change/ fix with the lift? will I need a longer driveshaft? brake lines?
the highest I've gone before was 3 inch on my bronco and is was pretty easy with no issues.
6 inch lift general questions
krafty
, Sep 26 2009 12:58 PM
Posted 06 November 2009 - 09:06 PM
okay, the kit I was looking at I think had the longer brake line parts.
I have the old cable speedometer so i'll just have to go out with the gps and note what speeds I will be running at.
Im not sure if I have the sway bar, but we'll see. I'm off work for a little bit on injury so money is tight, and I wasn't going to lift the truck till next spring after the winter anyways.
thanks for the info.
2003 F-350 5.4 Crewcab SRW
