My truck has no spark, I've replaced the dist. cranksensor, coil, the pcm, the starting solenoid, and i'm running out of things to replace, all the wiring tests fine. I'll get lucky and it'll start and run great, shut it off and let it cool down and it might be a couple weeks before it starts again.
![Photo](http://www.gravatar.com/avatar/bac71e4bcd5b18f0a984ac12942deeea?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
96 f150 I6 no spark
ohioseabee
, Oct 08 2009 04:39 PM
Posted 11 December 2009 - 01:47 PM
[quote name='ohioseabee' post='21403' date='Oct 8 2009, 04:39 PM']My truck has no spark, I've replaced the dist. cranksensor, coil, the pcm, the starting solenoid, and i'm running out of things to replace, all the wiring tests fine. I'll get lucky and it'll start and run great, shut it off and let it cool down and it might be a couple weeks before it starts again.[/quote]
[quote name=TOMMY9494 date=12/12/09,149PM ']
I HAVE A 94 FORD F150 AND IT HAS A THING CALLED A ICM THAT COULD BE YOUR PROBLEM NAPA HAS A LITTLE DEVICE THAT TEST THEM AND IF IT IS NOT THAT YOU COULD HAVE A SHORT SOME WHERE IN YOU IGNITION CIRCUIT AND I WOULD ALSO SEE IF ELECTRICITY IS GETTING TO THE COIL(/QUOTE)
