My truck has no spark, I've replaced the dist. cranksensor, coil, the pcm, the starting solenoid, and i'm running out of things to replace, all the wiring tests fine. I'll get lucky and it'll start and run great, shut it off and let it cool down and it might be a couple weeks before it starts again.
96 f150 I6 no spark
ohioseabee
, Oct 08 2009 04:41 PM
6 replies to this topic
Posted 14 October 2009 - 03:05 PM
Have you checked the ignitino switch on the column?
1985 Bronco 427 small block
C-6 with a 208 transfer
33x12.50-15 all terrain tires
Stock 5.8 with E40D tranny
Push button 4x4
32x12.50x15 Maxxis mudders
Push button 4x4
