I own a 96 F-150 swb 4x4, with a 16 gallon tank. I want to know if a 33 gallon bronco tank will bolt over with out much modifacation? Or where I can find an aftermarket tank larger than 19 gallons and smaller than 45 gallons.
More fuel range!
HalftonHighBoy
, Dec 07 2009 05:27 PM
Posted 10 December 2009 - 03:11 PM
Yep they fit . Will need tank sender ,straps ect . They r narrower front to back . A pc of angle iron will work to make up diff. And put spare in bed because way deeper.I would say it depends on distance between frame rails. Have you call for measurements?
There r several tanks that will give extra . But cost wise the bronco would fit bill.
Edited by lostin90s, 10 December 2009 - 03:14 PM.
Parts is parts
