steering problem
Posted 14 January 2010 - 12:33 PM
Posted 21 January 2010 - 10:45 PM
working to print out the $25 rebate form yesterday, and no one with the 1-800 new york escort
customer service line will help.
Does new york asian escort
ANYONE have the $25 Pandigital rebate form from Macys that they can send me? It was for this past weekend's salesnew york asian escorts
Posted 08 July 2010 - 09:59 AM
Sometimes when these old trucks sit they develop air bubbles in the PS lines. Try to jack the front end up and while the tires are off the ground turn the wheel back and forth to push the air out. Air bubbles will also form in the line when the PS fluid gets too hot so you might need a PS fluid cooler..i let my truck sit for about 6 months and finally i got the money to do some work and get her running and once i got her running the steering is messed up. when i turn the wheel there is power steering but it will bind up and then it will free up and then it will bind up whether im sitting still or moving. please help
Posted 21 December 2012 - 10:27 AM
Posted 20 July 2013 - 06:19 AM
I had the same problem with my 78 f150 4x4. The steering acted like it had detents in it, hard spots in steering. It was the u joint on the steer shaft binding up. My truck sat for 10 years, but had this problem previously. I had already replaced the steer box and pump then gave up. But after driving it and lubricating it with PB Blaster it loosened up and is okay now. Hope this helps.
Edited by kataz2000, 20 July 2013 - 06:20 AM.
