motor mount issues
Posted 25 January 2010 - 07:22 AM
Posted 19 February 2010 - 10:03 PM
Edited by fordtruckman, 24 March 2010 - 09:43 PM.
Posted 24 February 2010 - 09:17 AM
hey fordtruckman-thanks for the reply. the 79 4wd frame had a 300 stock I6 in it, which is the same engine I pulled from the 2wd frame and put into the 4wd. Wouldn't the frame mounts be the same? there aint any differences in the blocks that I can tell....you have to move the frame mounts for the enign eone way or the other to mount a 6 cyl in place of a fe eninge in a 4wd. the same goes if you do it to a 2wd truck. the enigne perches have to be moved forward in a 2wd when you swap a 6 cyl into a fe truck. if you have small block perches you may need different perches instead. the small block and fe / 6 cyl perches are different. the bolt holes for th emotor mounts are in diferent places. maybe 3/4 of an inch off.
Posted 24 March 2010 - 09:46 PM
