radius drop brackets or 7 deg bushings
Dano
, Jan 01 2011 04:25 PM
8 replies to this topic
Posted 02 January 2011 - 04:08 PM
Its possible to use only 'C' bushings, but I think for every 1" of lift you only lose 1.2 degrees of caster, so you may not need the 7 degree bushings. I'd think about installing the drop brackets because it helps with the contact angle and the wear of the R/A bushings, plus with the brackets, the spring seats won't be angled forward causing the springs to bow. You may want to check with the supplier, I think all you need is 2-4 degree bushings.
Posted 06 April 2011 - 04:13 PM
That's about as far as you go with a stock sway bar, i would get the adjustable type, and I also agree that radius arm drop brackets are better. Keeping the true angle of everything makes it easier on the truck. The angled C-Bushings, is what we refer to as Jerry Rigging when not in good company.I ordered some BDS 4" drop brackets today, I plan on replacing the C bushings to, do I use 2 or 4 degree bushings? I believe 2 deg. is stock from what I have read. And I imagine I will need to replace my sway bar links also huh? Thanks!
