I have a 78' F-250 Custom with a dana 60 rear end and floating axles. I recently decided to change the brakes on it. I found that the hubs were attached to the drums and appear to be welded on. has anyone else come across this same thing or have some helpful information on my drums? I would like to get new drums for the truck but can't seem to find any with the hubs attached also. Please help
1978 rear drum brakes
78GreenMachine
, Mar 14 2011 06:59 PM
Posted 19 March 2011 - 01:14 PM
there should be no reason why your drums would be welded on, unless you see welds on the hub flange it may just be rusted on. if the drum is indeed welded then you will have to remove the axle shaft in order to get a look at your brakes.
2003 F-350 5.4 Crewcab SRW
