Here's a pic.
So this truck is basically stock other than it has had a Cummins 4BT swapped in. The tranny is a BW t19. It still has the closed knuckle Dana 44 and manual steering. I want to swap the 44 out for an open knuckle, convert to disc brakes, and add power steering.
What I need to research and learn about is the best way to accomplish this. I also have a '66 Bronco that I swapped in a Dana 44 and converted to disc brakes and power steering but that was fairly easy given the aftermarket stuff available and the Bronco parts support. The F100 will be a little more of a challenge. The factory steering is behind the axle and the steering knuckle is on the left side. I'd like to get a steering box mounted ahead of the axle and come up with a crossover steering.
I'd appreciate any knowledgable input to this project.
