I have a 79 f150.. came stock with a 302 and c4 a/t. I have replaced the engine with a 302 (5.0L) from an 87 e150. All went well except now I have a vibration in the engine, appears to be in the rotating assembly. Does it any time, worse as rpms increase. Moving or not. Same trans as before, harmonic balancer from 79 engine. Any help??? Any ideas???
302 vibration
sajorf150
, Jun 29 2011 10:27 AM
Posted 04 July 2011 - 12:30 AM
Their are various causes for engine vibrations ,Check for lose or disconnected air or vaccum hose.It could also vibrate because your engine's one or two cylinders are not working properly causing engine miss.If it happens than check your spark plug ,it could be due to the spark plug conditions are not good.Also check the ignition wires connections they should be connected properly.Even harmonic balancer worn out can create engine vibration.
