I have a 1991 f350. The fuel pumps did not run.
1- Changed the fuel pump relay, did not fix
2- changed fuel pumps, noticed there was only 7.5 volts at the pumps
3- Ran the KOEO test , code 95 displayed "fuel pump circuit failed- PCM to GRD", can not determine if it might be a failure in the ECM(computor). Any suggestions?
![Photo](http://www.gravatar.com/avatar/6151968c10397c120b3646d8a7ec8c68?s=100&d=http%3A%2F%2Ffordfzone.com%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
1990 Ford F350 Gasoline Engine
racer32
, Sep 14 2012 05:37 PM
