brakes pulling when braking
larmill36
, Jan 14 2014 05:08 PM
Posted 14 January 2014 - 05:08 PM
Hey I have a 93 ford bronco replaced lines pads rotors calibers everything I can think of still pulling hard to the left.thought it might be abs pulled the fuse still pulling. Tried bleeding brakes again and noticed I can only bleed right caliber while truck is off when on hold brake down open bleeder valve nothing comes out and peddle doesn't move. Any advice is appreciated
Posted 15 January 2014 - 08:58 PM
Welcome to the Ford F Zone!
Since you have a Bronco related question I would like to point to over to the larger Bronco community. More people are active over their so you will get a quicker response.
I will leave your question up here just incase you get an answer
