What size lift and wheels would I need for 36in tires, and would I need spacers for them? Just bought a 1992 F-150 with a 351 Windsor in it and trying to turn it into an offroad mud/play toy.
Right size lift and wheels for 36x14.50 tires?
Posted 14 May 2014 - 10:09 PM
Needing spacers would depend on what Back spacing your rim is. Note: Using spacers makes the weight of the axle ride differently and could wear out you wheel bearings quicker (I personally have been warned of this). Note #2: I've seen tons of people run wheels with spacers with no problem.
I don't know much about lifts but here is what I know for a fact, You will need at least a 3" lift to fit those tires. Most people running that size of tire have a 4-6" lift.
Body v.s. Suspension lift? Again I'm no expert but I would use only a suspension lift kit. You will need longer front and rear drive shafts after you a suspension lift over 3".
Hope this helps.
Posted 17 May 2014 - 08:59 AM
yo B,
WELCOME!
Is it a 4x4?
Tire - Lift Guide, Bronco & many makes; w/Wheel Diameter, Width & Offset
Source: by Skyjacker®
http://skyjacker.com...andwheelcha.pdf
For backspacing
please consult your local tire, wheel & Lift specialist.
Thanks to All Who Serve
