i have a 1995 f350 xlt gas 7.5l 4x4 crew cab with auto trans. i am having a problem switching tanks. i foolowed your advice subford as on other posts and found a problem with the inertia getting power. that bieng solve it will now pump but i get no fuel to fire the engine. previously i had no powewr to tank switch but i have temporarly jumped it to figure out the problem.the guy i got it from said the front tank never worked. so i got a new spectra fuel pump n hanger the complete assembly. boom no prob right? thats when i started reading on it and found the prob at the relay. that bieng said do i have a tank selector and if so any pics? ive followed the fuel lines and see nothing. did they bypass it? thanks
cant get side fuel tank to switch
Joedirt1971
, Aug 10 2015 09:07 PM
Posted 12 August 2015 - 06:07 AM
yo Joe,
GOOD DIY!
Fuel Tank Selector Switch PIC in a 95 http://www.oreillyau...-350&vi=5007033
Wiring Diagrams showing Fuel Tank Selector Switch in 95 F350 7.5
http://www.revbase.c...loadPdf?id=2026
for depictions & info, see FYI,
96 Bronco-F-Series Workshop Manual (PARTIAL)
http://www.diesel-da...stj/stjleft.htm
Same as most earlier years exc. for OBD II in 96, 3 Screw Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
For tank info;
Section 10-01A: Fuel Tank, Filters, Tubes and Electric Fuel Pump, Gasoline Engines
Fuel Tank, Steel Midship, F-150, F-250, F-350 and F-Super Duty
http://www.diesel-da...tj/stja1a14.htm
NOTE: As there are different midship fuel tanks (9002) which are removed and installed essentially the same way, follow steps and refer to appropriate illustration
Fuel Tank, Aft-of-Axle, F-150, F-250, F-350 and F-Super Duty
http://www.diesel-da...tj/stja1a15.htm
GOOD DIY!
For tank info;
Thanks to All Who Serve
