Posted 31 March 2004 - 09:57 PM
83Bronco, have you seen the commercial for WyoTech, where the girl comes up to two dudes playing basketball, and shows them a picture of an old Ford truck (1950?) with a flamed paint job and such and says, "I worked on it"???
Anyway, that is some serious rust on the floorpan. You can buy new panels to weld in place of the rusted ones, but you will prolly spend at least a few hundred bucks doing that. You can find another Bronco or Ford truck and cut the good sections out of it and use those, or you can find some bare sheetmetal and cut that to fit over the holes. Even an old piece of tin, like you see on an old barn or chicken shed can be made to fit. Some tin shears, a hammer to flatten it out, and if you want to get fancy you can pop rivet the panels in place. Or just drill holes in the good metal and secure the patch panel with screws. I did this to an old Chevy Blazer, and my neighbor did that in some spots on his 85 Bronco. Only problem you may have is if any of the frame supports or crossmembers are rusted also. I would venture to guess that those are. Again you can buy new ones for the floor and cab supports, or get some out of a used truck.
If you are serious about fixxing this thing up in auto mech class, and your teacher is willing to let y'all learn on it, I can send you a few parts from my 88 Bronco if you absolutely cannot find them closer or they cost too much. I can cut a piece or two from the floor and a frame support here and there. Any donations to cover shipping will be acceptable, but not a must. I can't help you on the rear seat since it's not in that great a shape, but the floor area is rust-free.
It would be awesome to do a tech write-up on this as work is performed!!!
