I am considering removing the smog pump and all associated parts and hoses on my 1985 F150 with 351W H.O. Engine. There is just too much stuff clogging the engine bay. First, how difficult of a project is this? Is it a simple removal or do I need to alter how some things are ran or what? Second, is there anything I should be aware of as far as anticipated complications? Third, are there any performance changes, good or bad? I currently do not have a belt running to the smog pump anyway.
1985 F150 351W Smog Pump/Emissions Removal
85Fordx4
, Aug 01 2016 05:36 PM
Smog Emissions 1985 4x4 V8 351W
4 replies to this topic
Posted 03 August 2016 - 12:59 PM
Yo,
Welcome!
These parts are commonly used & available via google searches
Eliminator Overview, EGR Block Off Plate, EVR, CANP, TAB & TAD Actuator Eliminator Resistor & Parts List & pics; need one 75 ohm 3watt Resistor for each item removed, EVR, CANP, TAB & TAD solenoids
Some pics of each, but company is out of business
RJM Injection Tech EGR Eliminators
http://api.viglink.c...EGR Eliminators
Tad and tab resistors see wiring resistors in for TAB/TAD, how to?
http://www.fullsizeb...ab-tad-how.html
EGR Location & Block-Off Plate pic in an 89
Source: by Tim C (TnTbronco2, Trail Truck, Street Truck, Crazed, Broke, OoG) at http://api.viglink.c...SuperMotors.net
Eliminator Installation Manual by Ryan M.
http://api.viglink.c....eliminator.pdf
"...What you need to do is plug resistors in TAB and TAD solenoids, remove the vacuum lines, then all the air injection plumbing and valves can be removed and the heads plugged. The EGR is a seperate system from the Thermactor and the computer treats it very differently, it also helps increase milage and power so it's a good idea to keep it anyway. If you have the DPFE system there is no way to bypass it without the computer knowing and throwing a code so you may as well keep it intact. you'll get codes if you remove the solenoids, the easiest way to avoid this is to just leave them plugged in. The TAB and TAD you could fake out pretty easy, but even the old EGR system can't be faked because the computer both commands valve movement and watches for feedback to confirm it happened, so a dummy resistor won't cut it. by Paul
Removal, Belt Part Number in an 89 5.8 Bronco, but should be the same; NAPA Belt Part # 060825
Source: by Cucamongan (Scotty)
http://www.supermoto...try/15996/70029
Welcome!
Thanks to All Who Serve
Posted 04 August 2016 - 10:34 AM
Yo,
I should have asked if it was carbed or efi!
I am wavering on what to do with the egr... here is best info I have, but it is not exact, depending on carburetor or intake changes made by previous owners;
http://forums.corral...26658?_k=x2dz7c
Some owners have issues with engine running too lean, vacuum leaks, etc.
Posted 04 August 2016 - 12:54 PM
Also tagged with one or more of these keywords: Smog, Emissions, 1985, 4x4, V8, 351W
Technical Support →
80-96 Ford Truck Tech Support →
Turn Signal MalfunctionStarted by 85Fordx4 , 01 Aug 2016 ![]() |
