Carburetor replacement... advice
#1 Lando104
Lando104
  • Favorite F-Series Year?:1984
Posted 23 August 2016 - 03:13 PM
Hello... In need of some advice, I looking in replacing the carburetor on my 1984 Bronco that has a 302. I have been looking at the Edelbrock Carburetor to purchase, I only use for road use and a little off road. When I look at the current set up of Vacuum lines to the stock Carb its a mess , the pump has already been removed for pollution . What Im looking for is advice on what carburetor is suggested and should i replace the stock intake manifold also and what can I remove when after installing a after market Carb .. like Vacuum lines..
Thanks
#2 miesk5
miesk5
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 145 posts
Posted 24 August 2016 - 12:35 PM
Yo Lando,
Welcome!
Suggest you register and post this question @ our sister forum,
http://broncozone.com
I believe some have 83-84 Broncos with carburetor changes.
Thanks to All Who Serve
