Does anyone know what sort of MPG i am getting in my Bronco? its an 83 with an inline 6. Also what kind of horsepower does that get? if anyone knows that off the top of their head it would be great. I was just curious. Thanks!
~Sarah
Mpg And Hp
Guest_83Bronco_*
, Apr 06 2004 02:51 PM
8 replies to this topic
Posted 06 April 2004 - 07:35 PM
engine specs
according to this chart, you should get about 120 HP and 250 ft.lbs. of torque from a 30I-6 that is properly tuned and running well. That seems like it's nothing by the numbers, but believe me, the I-6 can tow up to 15,000 lbs. and never grunt. As for gas mileage, average is about 10-14 mpg, but you need to see how far you go from one fill up to the next. 300 miles divided by 30 gallons is 10 mpg.
Posted 07 April 2004 - 07:06 AM
To get the MPH is easy.
First if you have a "Trip Odomeater" just reset it when you fill-up. Then next time you fill your tank write down the miles (i.e. 152.6) then devide that by the gallons your truck took (i.e. 25.876) and the answer is your MPG.
I am making a table that I will post later for all to use.
- 152.6 Miles
- 25.876 Gallons
- _____________
- 5.897 Total
- or 5.9 MPG
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
Posted 07 April 2004 - 04:08 PM
ratings gave above sound right. the 300 6 ain't a HP monster it's a TQ monster. the TQ is what you want in 4x4 bronco/truck. But if the cash is right you can build that 300 to blow the doors off most V-8's. do a search over the 300 you'll find lots of info bout it.
Guest_83Bronco_*
Posted 07 April 2004 - 06:30 PM
wow, thanks guys for the replys. this has more hp then my 88 ranger!! hehe. yea i can tell it has tourque. i wish the MPG was better, but oh well. I really dont plan on modifying the engine , just keeping it stock. I cant afford anything else just yet. thanks ! ~Sarah
![:)](http://fordfzone.com/forums/public/style_emoticons/default/smile.gif)
Posted 07 April 2004 - 07:34 PM
If your motor, transmission, axles and transfer case don't show any signs of a leak then try switching all of the above to full synthetic oil but ONLY IF NOTHING LEAKS! If there are any leaks at all then the synthetic oil will only make the leak worse. You should get better MPG after that.
90 Bronco Full Size
Police Package
351W
E4OD
31" Tires
Police Package
351W
E4OD
31" Tires
