Bad Rear End
#1 Guest_BLADE_*
Guest_BLADE_*
  • Guest
Posted 10 April 2004 - 09:16 PM
I have a 1986 F250 witch i use as a tow rig and the ring and pinion is bad now. The question is all the listings that i have found are for a 10.25 ring and mine measures 10.5. Is it that I'm measuring wrong or is there a 10.5 ring and pinion out there?
#2 Guest_jfrbronco_*
Guest_jfrbronco_*
  • Guest
Posted 10 April 2004 - 10:16 PM
check for the axle codes, maybe on the pumpkin there is a tagor or the drivers door there should be a axle id code on the sticker. With that code you can tell whats in there.
JFR-
