what are the biggest tires you can put on stock? i here 33x12.50's or would 32x 11.50's fit a little better with less rubbing??? im lookin at BFG mudders
Biggest Tires On Stock?
Guest_blitz4075_*
, Apr 26 2004 06:31 PM
9 replies to this topic
Posted 26 April 2004 - 08:25 PM
31x10.5 whatevers; No rub
32x11.5 whatevers; Little rub depending on bs of wheel
33x12.5 whatevers; Lots of rub/might not fit depending on how much sag is in your springs/bs of wheels
I highly suggest the 31X11.5 Super Swamper LTB or Possibly their 34x10.5 LTB because the LTBS tend to run heiniously small, and if i recall only measures to 32". Oh yeah Ltbs are very cheap.
Rigs
#6 Guest_Gunner_*
Posted 27 April 2004 - 08:21 AM
the length of the tire doesnt really matter. i men you should be able to fit a 34 with no problem. it is the width that will give you problems on a non lifted truck. 10.5 wont rub at all. 11.5 will rub a little when wheel is turned hard. forget 12.5 if you arent lifted. even a 3" body lift will get 12.5 to fit no problem. i have a 3'' body lift with 35x12.5R15 BF Goodrich all terrains and i have no rubbing anywhere.
#7 Guest_ratmrage_*
Posted 29 April 2004 - 07:20 AM
I am kind of new the the bornco scene. I bought an 89 fs. It has 33-12.5's on it. In fact I just put 2 new ones on the front, along with new tierods and a pitman arm, $585.00. My tires do not rub at all, so does that mean I have a lift kit on her?
#8 Guest_southerntrax_*
Posted 29 April 2004 - 06:35 PM
no its dosen't mean you have a lift. are you runnign stock or aftermarket wheels. aftermarket wheels might have more of a backspacing. i have an 84 bronco that the front springs and shocks were wore slam out. i was running 15x8 wheels with a 4 inch backspacing and only rubbed one the passenger side at a full lock. so it also depends on what type of wheel you are running as well.
#9 Guest_ratmrage_*
Posted 30 April 2004 - 07:56 AM
I have aftermarket rims. They are made by american racer or american racing. 12.5 inchers. I have been trying to find out what they are worth, but they are discontinued. I have been told they are basically worthless to at least worth over $400 for the set without rubber. I wouldn't mind going to a stock tire and rim but since they were on it when I bought it I will probably keep them.
#10 Guest_CADster_*
Posted 30 April 2004 - 10:48 AM
i think it depends more on how/where you drive and the rim width. narrower rims will allow a taller tire. this will not help if you rock crawl but will be fine for cruising the beachwhat are the biggest tires you can put on stock? i here 33x12.50's or would 32x 11.50's fit a little better with less rubbing??? im lookin at BFG mudders
will the later year fords with the radial fender arches house a bigger tire then the ealier models ?
