Great Spark!
Guest_78mojavebronco_*
Posted 28 April 2004 - 07:26 AM
part#8350
Posted 28 April 2004 - 07:58 AM
http://www.superford...Picture 017.jpg
Posted 28 April 2004 - 12:19 PM
Posted 28 April 2004 - 05:51 PM
Posted 22 June 2007 - 01:18 PM
you say it does away with the ignition module on the drivers side i have a 79 and i am wiring up the MSD6 offroad ignition i all so have the MSD distributer and one more ? on the MSD box the main ground do you half to run that to the battery or can that just run to a good ground just asking becase my battery is in the bed
Thanks for the info Freak.
#11
Posted 02 July 2007 - 06:41 PM
#12
Posted 22 October 2007 - 10:11 AM
I never knew that about the platinum tip plugs. I have been having a ton of problems with my truck, all of which has happened since I changed spark plugs. Otherwise I have never had any troubles at all with my MSD set-up. I will have to try that remedy. Where does it state that about the platinum tips, I never say that anywhere in the manual that I remember. I sure hope I did not ruin the control box none. Thanks for the heads up!do yourself a favor and keep the duraspark mounted as a backup. If you installed the 6al control box using the white wire hookup it should be an easy emergency swap back when it fails out in the boonies. also, never run any type of platnum plug, you'll immediately melt the tips and can damage the control box
Beat on it.
Break it.
Build it better.
#13
Posted 20 November 2007 - 07:24 PM
