Hardtop Paint
6 replies to this topic
#1 Guest_fordguy782001_*
Posted 08 May 2004 - 09:10 PM
the paint on my hardtop is coming off. does anyone know what kind of paint to use on it?
#2 Ziggy
Ziggy
    F-Series Maniac
  • PipPipPipPipPip
  • 140 posts
Posted 12 May 2004 - 12:28 PM
Mine is the same way. I am going to try a "fiberglass bathtub" refinishing kit I bought at Home Depot. Kit basically recoats with a layer of fiber glass resin. I used the same stuff on my bath tub when I remodeled the bathroom. I figure it will work my shell since they are both fiberglass. Kits only come in white and almond. Since my shell is white, it should work. It will be a gloss finsh instead of a flat finsh. But I figure the gloss finsh will help shed dirt better.
#3 Guest_fordguy782001_*
Posted 06 June 2004 - 08:44 PM
I thought about using a brush on bedliner on my top would it work?
#4 mgawat
mgawat
    Duck Tape L'fixer :)
  • PipPip
  • 24 posts
Posted 15 June 2004 - 12:48 PM
B) I've used marine pain (for fiberglass) with alot of success. Mostly Petit and Interlux. The Interlux goes extemely easy and can easily be made flat by adding the Interlux thinner. Hope this helps.
#5 Guest_custom_78_*
Guest_custom_78_*
Posted 03 July 2004 - 08:00 AM
Will regular acrylic automotive paint work because I don't have much money to spent and want it to match my Bronco's body?
#6 mgawat
mgawat
  • PipPip
  • 24 posts
Posted 03 July 2004 - 09:57 AM
:mellow: I would ask your paint manufacturer. (Corvette's are fiberglass also). ><img src=<' />
#7 Guest_custom_78_*
Guest_custom_78_*
Posted 04 July 2004 - 07:44 AM
I asked someone and they said that you have to put an additive in the paint to make it flexible.
