Tachometers
Posted 18 May 2004 - 07:05 AM
Having a tachometer is always a good thing, you can use it to see if there is a problem and you can watch it to try to save gas.
Police Package
351W
E4OD
31" Tires
Guest_Guest_*
Posted 18 May 2004 - 06:43 PM
Posted 18 May 2004 - 06:51 PM
Posted 19 May 2004 - 07:50 PM
Posted 21 May 2004 - 05:24 AM
Police Package
351W
E4OD
31" Tires
#11
Posted 21 May 2004 - 11:59 AM
#12
Posted 21 May 2004 - 02:09 PM
One more thing no one mentioned ....You have to take the cover off you steering colum to disconnect the Gear Indicator cable. BE VERY CAREFUL!!! the cable is inside a tiny plastic tube that is very brittle. If you break it, your indicator won't work properly, it can not be fixed, only replaced. The CHILTON's manual outlines this procedure step by step. If you don't have this manual, it is well worth the $24. It has saved me thousands.
351W HO EFI
3 Speed Auto
#14
Posted 22 May 2004 - 04:34 PM
I have a tac in my garage. You may also have to add a fuse #18 ( atleast that is the number on a 1983 FS Bronco,. Fuse 18 covers a lot of misic stuff.
#17
Posted 24 May 2004 - 04:56 AM
The most critical part is removing and reinstalling the steering column shroud. You have to be careful of the shift indicator wire and attachment to the cluster. Once that is off disconnect the shift indicator wire from the left side of the column. I can give you the complete proceedure if you like which you will need no matter which way you decide to go.
#18
Posted 24 May 2004 - 05:57 AM
Email me if you want the tac. Help clean out my garage.
