I took my 85 out the other day and played in the mud with it a little bit. I have only done this twice since I bought the truck but I have noticed both times that the motor seems to get unusually muddy. Is this just the way ford designed the engine compartment or is there supposed to be some sort of a mud flap underneath like my cherokee had. Also if anyone has rigged a flap for there bronco let me know how you did it or send me pics.
Saint351
Muddy Engine
Guest_Saint351_*
, May 14 2004 05:56 AM
5 replies to this topic
Guest_Saint351_*
Posted 14 May 2004 - 06:12 AM
Yah that inner fenders are on there. I probably hit the puddles a little faster then I shoulda but it still seems just to dirty for the little bit that I done with it. I remember taking my cherokee out before I had the lift in it and just giving it through deep holes having wather splash everywhere, and even after my little mud flap came off I never had that much dirt and mud on my motor. Broncos and cherokees are 2 different worlds though so Im probably wrong for even comparing them.
Saint351
Saint351
Posted 14 May 2004 - 08:09 AM
alot of the mud and water gets slung around under your hood by the fan. If you do away with the fan for elc. fans so you can turn them off when in deep mud/water will solve alot of the mud/water slungg under the hood.
Posted 14 May 2004 - 08:27 AM
I had this problem and went with electrics and now the engine compartment is clean but on hot days or on the freeway she would heat up. The bad thing about electric fans is they only run at one speed. This keeps up with trail driving or slow going roads. A mechanical fan will turn as fast as the engine so it can keep up with the heat and high RPM's. A clutch fan always heps but you will still sling mud.
So I run electrics in the winter with the cold air and deep mud and run mechanical in hot summer. Although I still see lots of mud here in Washington durring summer but what can I do but get in it?
![:))](http://fordfzone.com/forums/public/style_emoticons/default/haha.gif)
Wheel it like you stole it!
