Are there any power steering pumps that are more heavy duty and will fit on my 300 six?
Power Steering Pump
Guest_83BRONCRAWLER_*
, May 20 2004 12:31 PM
7 replies to this topic
Posted 23 May 2004 - 03:00 PM
Well you could go for a serpintene conversion kit or mount up a second puley. this should stop the slippage and then the pump would do better. If you can afford it, buy a FI 351. it should have a serpintine belt, do better on extreme angles and have more torque. im shure that there are conversion kits for larger power steering pumps out of superdutys and things like that though but you will just have to look around. go here for a souped up reman pump.
Posted 23 May 2004 - 07:02 PM
I have a complete 351 HO sitting in shed, all pulleys and accessories intact if you want to convert to serpentine, I think it has the saganaw pump(will check and get back to you) which is a stronger pump. All I want is the long block for "just in case". Also no A/C compressor . It has the eliminator bracket w/pully .
1989 EB Bronco
351W HO EFI
3 Speed Auto
351W HO EFI
3 Speed Auto
Guest_jermil01_*
Posted 24 May 2004 - 11:31 AM
The saginaw pump swap has been a pretty popular mod, if you go to www.fullsizebronco.com and run a search you will come up with a lot of information on the subject. Stock c2 pumps that came with are rigs are woefully inadequate due to their low flow rate. If you need more info let me know.
