Rearend Swap Need Help
Posted 22 May 2004 - 02:54 PM
Posted 26 May 2004 - 06:13 AM
Guest_jfrbronco_*
Posted 26 May 2004 - 02:55 PM
1 should I change the yoke and use the 89?
2 if I'm going to change the yokes should I just leave the 94 housing together on the truck so I don't have to mess with the brakes and swaping it all over and just do the interals?
3 any daigrams out there for me to look at?
4 have done gear changes alot on f-body's but this is my first ford ( for that matter 4x4 )
any help or advice would be great and help both of us.
Thanks JFR-
Posted 27 May 2004 - 10:20 AM
Sorry Kelly, I just noticed you said E250 and not F250. I dont think you can use this 9" rear.
Do like 4Xfan78 said, you will see that one side is longer than the other.
351W HO EFI
3 Speed Auto
Posted 22 June 2004 - 08:10 PM
#11
Posted 23 June 2004 - 03:30 PM
#12
Posted 23 June 2004 - 07:57 PM
#13
Posted 24 June 2004 - 11:11 AM
Since it was Free and the Right gear ratio in the 3rd member. hit the junk yards looking for a core rearend that the gears are shot in the 80-86 4x4 range cheap. That way if the gears in the Free 9" you got are good you'll have a good 3rd member to slide right into a good housing and axles. why 4x4 is because they use a wider leaf spring perch then a 2wd model. If i remember right the 2wds use a 3" wide sring and perch while the 4x4's use a 4" wide spring.i made sure it was a 9 inch before i got it. front carrier case and it matched up with every picture i could find. if the modifications are going to be too much then i'll find one that fits. which ever one i got i was going to overhaul anyway but this was free so i wanted to see if it would work.
#15
Posted 03 July 2004 - 10:22 PM
