![:unsure:](http://fordfzone.com/forums/public/style_emoticons/default/unsure.gif)
Starter
Guest_bluryeyes_*
, May 25 2004 07:27 AM
Guest_bluryeyes_*
Posted 25 May 2004 - 07:27 AM
Guest_Gunner_*
Posted 25 May 2004 - 08:33 AM
no they are not interchangeable. the teeth count on the flywheel are different. the 351 has more teeth so the spacing on the starter teeth are different. it will work for a little bit but eventually the starter will eat the flywheel or vise versa depending which metal is harder which is usually the starter. anyway i wouldnt interchange the starters if i were you.
