Power Steering Pump Issue
5 replies to this topic
#1 Guest_stankydude_*
Guest_stankydude_*
  • Guest
Posted 27 May 2004 - 06:28 AM
Howdy all,
I just had my tired 351m swapped with a rebuilt 390 in my 78 F-250 super cab. The engine was complete, but the guy used my old power steering pump. He ran one long belt to all four pulleys closest to the block (alternator, crank, fan and ps pump). This causes the belt to be within 1/8" from the lower radiator hose on the ps pump side and it is rubbing.
So I'd like to put spacers behind the ps bracket to bring the pulley even with the second groove on the crank, and run two belts. One for alternator, crank and fan (on the first groove) and one for power steering pump, crank and fan (on second groove).
ONE PROBLEM :wacko: the ps pump pulley is within 1/4" of the steering box, so if I want to move it forward to line it up, I'll have to swap the original 6" pulley with a 5 1/2" or 5". I can't move the entire pump any closer to the block either, so I can't really see any other solution (other than a whole new pump???).
so if anyone's ever had this problem, could you please let me know where the heck you got a new ps pump pulley.... I can't seem to find one anywhere.
many thanks,
Aaron (stankydude)
#2 4xfan78
4xfan78
  • 432 posts
  • Interests:Anything Ford prefer 78-79 bronco<br>The bigger the better
Posted 27 May 2004 - 10:05 AM
Try using the 351 brackets on the 390. Dont know if this will work but its an idea.
GOT MUD?
#3 Guest_stankydude_*
Guest_stankydude_*
  • Guest
Posted 27 May 2004 - 10:20 AM
Thanks 4xfan78, but I already gave that a try. The bracket sits too low and the pump winds up hitting.
I appreciate your input though.
Aaron (stankydude)
#4 4xfan78
4xfan78
  • 432 posts
Posted 28 May 2004 - 07:10 AM
All else fails change the pump pulley, the 5" should work might turn alittle faster but I do not see how that can hurt as long as you're hoses are in good shape.
GOT MUD?
#5 chinnookcrazy
chinnookcrazy
  • Favorite F-Series Year?:1979
Posted 14 June 2016 - 12:00 PM
anyone find a solution? I have the same problem. I am looking at making one if I cannot find one.
#6 miesk5
miesk5
    F-Series Maniac
  • Moderators
  • PipPipPipPipPip
  • 145 posts
  • Interests:Broncos, beach runs, surf fishing
  • Favorite F-Series Year?:1996
Posted 15 June 2016 - 02:55 PM
Yo,
What engine?
Try:
http://www.cvfracing...mupUaAjOD8P8HAQ
http://www.speedwaym...pyvgaAr5b8P8HAQ
http://www.stangerss...ppulleyID1.html
Good luck!
Al
96 Bronco, E4OD, Man Xfer Case & Hubs
See my Big Bronco & F Series Technical & Parts LINKS site. Will need to clean up dead links & add many more new links some day. Thanks to Mr. Schwim! http://schwimserver5.com/?index=1128
Thanks to All Who Serve
