'79 Bronco
#1 Guest_goalie_*
Guest_goalie_*
Posted 26 January 2004 - 06:21 AM
The '79 Bronco I have is slowly coming back from the dead. However, the rear window is a problem. I have checked the motor for the window and it works fine (out of the vehicle), the switch on the dash apparently does not work and the tailgate swich does not work. I read where ZIGGY gave out the part # for the switch, would anyone out there have any other info that might help.
Thanks in advance.
#2 davids78bronco
davids78bronco
    fabricator extraordinaire
  • 294 posts
Posted 26 January 2004 - 08:18 PM
It's time to chase down the circuit. Check for bad fuses, a bad relay, are the tracks properly lubed?
#3 Ziggy
Ziggy
    F-Series Maniac
  • PipPipPipPipPip
  • 140 posts
Posted 28 January 2004 - 08:38 PM
"the switch on the dash apparently does not work"
Are you sure on this one? You say the motor works out of the truck but not in. The gear in the motor may be bad. There are 3 small pieces of soft plastic in with the drive gear that over time will give out and the gear will slip while putting up you window. The motor will work fine until a load (weight of window) is added and then nothing happens. Try checking this out, replacement gear can be bought at any auto parts store for around $5.00 - $10.00. Been there, done that.
#4 GubNi
GubNi
  • 7 posts
Posted 24 February 2004 - 12:28 PM
Most of the time it's the latch closed sensor. The window won't go up if the tailgate is not closed. If your sensor is rusted it may think the tailgate is open. I find it's more often the right side. You need to take the inner tailgate cover off and lube everything up and make sure it all works. It's been a few years, so I don't remember exactly what to do, but it's a common problem. It seems like you need to take the latch off the tailgate to service it.
79 Bronco 460, C6, Dana 60HP with Electrac locker, Dana 70HD with detroit locker, 44's, Milemarker 10.5k Hydraulic
78 Bronco 460, C6, Dana 44HD, Dana 70U with detriot locker, 36's, Milemarker 9000lb electric, dual batteries
