Another New Guy
8 replies to this topic
#1 Guest_big b_*
Guest_big b_*
Posted 22 July 2004 - 07:58 PM
hello bronco world! I just bought my first bronco about 2 weeks ago. As I was driving it home I noticed that the steering wasn't responding quite the way I expected it to. I talked to a couple of guys about it and they said that it probably was my steering gearbox. So without taking the truck apart what is ths easiest way to check the steering box? :wacko:
#2 fbrown3
fbrown3
    F-Series Mechanic
  • PipPipPipPip
  • 53 posts
  • Interests:Hunting,Fishing and spending outdoor time with my boys, playing with the BII
Posted 22 July 2004 - 09:07 PM
Read the miss matched suspension lift article above your post, should give all the info you need.
#3 Ktomek06
Ktomek06
    F-Series Commander
  • Moderators
  • PipPipPipPipPipPipPip
  • 509 posts
Posted 23 July 2004 - 05:09 AM
Welcome to the Zone!
#4 Guest_Guest_*
Guest_Guest_*
Posted 23 July 2004 - 12:29 PM
howdy and wlecome LOL. :D this is a very good board B)
#5 Guest_matt_*
Guest_matt_*
cool i don't got to register
#6 Guest_badboyman_*
Guest_badboyman_*
Posted 23 July 2004 - 12:31 PM
welcome to the board!
#7 Guest_custom_78_*
Guest_custom_78_*
Posted 23 July 2004 - 01:37 PM
Welcome to the B-zone. I had to replace my steering box because it was rear stiff. I first had to replace the steering pump then the lines then I knew it was the box.
#8 Guest_badtodabone_*
Guest_badtodabone_*
Posted 24 July 2004 - 10:42 AM
Hi Hello! and welcoe to one of the best boards around.
#9 Justshootme84
Justshootme84
    F-Series Commander
  • Moderators
  • 914 posts
Posted 29 July 2004 - 09:31 PM
Welcome, Big B, to BZ!!! Check for any slack or play in the steering linkage and steering shaft. There is an adjustment screw on the gearbox, too. Tighten it only in 1/4 turn increments, though!
