What are you plans for the truck. Do you plan on lifting it. It sounds like you know alot about systems. I have 2 Rockford Fosgate 15" Power HX2's and 2 Lanzar Competition 1500D amps. It knocks a little
. I have some trouble with the power sources. If I'm going to wire up a yellow top Optima battery, should I run it through my altenator or should i just wire it straight to my amps. If I run it straight to the amps I'll have to charge the battery every night... Well any help you can give is appreciated.
I would definitely recommend upgrading your alternator. You could use two batteries, but that would increase the strain on the alternator. I would just go with the Optima, upgraded alternator (get a good one, like from www.mralternator.com ) or at least get your original one rebuilt to run hotter, which will put out more power and make it run more efficiently. I would also upgrade the ground wire on the battery, the one going from the chassis to the battery. Check this page out:
http://forum.sounddo...ic;f=5;t=007801I don't plan on lifting it, but I wanna put 33"s or something close and some 15-16"s on. A brush guard, getting tint, clear corners, and some other little stuff down the road, too.
Some good places for audio are:
www.sounddomain.com in their "open box" section for good new stuff with warranties, and
www.ikesound.com for stuff without warranties. Find what you want, and search it up on the net. I talk on SoundIllusions.net and do some frequent audio discussion.
Thanks a lot for reading my post. It's my b-day today, so I'm gonna try and get my box for my JBL W10GTi built later on, and get drunk, too.
L8r!
