Oil Pressure
bigbad79
, Sep 24 2004 12:31 PM
12 replies to this topic
Posted 24 September 2004 - 12:31 PM
does anyone know any tips to get a correct reading on oil pressure? i just replaced my oil pump and changed the oil of course. when the truck first starts the oild pressure reads about 25 to 30 psi. then as the truck warms up the pressure drops till the gauge reads 0. i dont think its the gauge since its a brand new autometer. what else is there to replace? the motor sounds fine even when the gauge is reading zero, no knocking or anything unusual also
Posted 25 September 2004 - 02:42 PM
yeah i replaced all the fittings and hose to the gauge and the pressure when i first fire the truck reads at about 50 psi which is pretty normal i guess but it seems that as the truck warms up the pressure still drops till it reads zero. with the new hoses and fittings it took a little more time than before but still the same result. what else is there to look at?
Guest_BigNasty_*
Posted 26 September 2004 - 03:06 AM
Hurricanes?
Yeah, no kidding!
The rain from the first one that came thru flooded my engine and I didn't know it till I went to crank it.... and now another ones in Florida...
Florida is nothing but a storm magnet this year... I feel we should sink it and move on
Yeah, no kidding!
#11
Posted 27 September 2004 - 09:42 AM
You should bleed out the air in the oil line. Take the tube off the back of the gauge and tick the engine over a few times until oil sprays out the tube. The reconnect it and test it after you top off with 20/50 oil. Air doesn't compress the same as oil but should keep you close to accurate even with air in the line. Seems odd to have 0 psi after seeing 50 psi. Try some Hyper Lube woth 20/50 or perhaps the oil pump is shot.
Wheel it like you stole it!
#13
Posted 28 September 2004 - 09:43 AM
so after bleeding the line to the gauge, changing the oil for some 20/50 and changing the oil pump i still have the same problem. i'm gonna try using the old pep boys gauge that was in it and see what happens, maybe the autometer is a defect? i'm just about out of options
