An axel broke on my 70 F-1. The rear end is from a 67 F-1. The rear end is true posi. Does anyone have and idea from what year truck I could get one. I want to know If I could use one off of a 67 bronco.
67 ford posi axle
70blueF-1
, Jul 24 2005 09:16 PM
Posted 01 December 2011 - 02:25 AM
If the 67 Riv is a GS model, it should have a 3:42 posi. If not, it's probably a 3.08. Either way, it looks like you'll have to swap the ring/pinion. Both should be the 9 3/8" rear end. There is a possibility that the LH carrier bearing may be different between the two as there was an early '67 change to increase the size of that bearing. That's why you see carrier bearings listed as '66-'67, and '67-'70.
